Re: Hunt condition Farmall 140
Posted by Janicholson on February 26, 2010 at 18:45:23 from (64.61.211.35):
In Reply to: Hunt condition Farmall 140 posted by Griff NC on February 26, 2010 at 17:22:38:
Hunting at High Idle (little load full throttle)
is caused by one (or a combination of) these:
Governor linkage to carb loose at the pivot points.
(Redrill the holes and use a larger diameter rod with a threaded on clevis to tighten it up and be adjusted so full throttle from governor is full throttle plate open.)
Governor bearings worn out.
(Rebuild the governor)
Carb either rich or lean at high idle.
(Adjust the carb)
Fuel delivery restriction in main jet.
(Clean the carb then adjust)
Broken advance springs in distributor, bad timing.
Check rotor for spring action in the CW direction, if none, or it stays where it is put, repair.
The throttle saw teeth can be filed deeper with a small triangular file.
Jim
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
