Posted by SaTom on February 27, 2010 at 10:13:24 from (76.23.205.193):
In Reply to: Re: SA Cultivators posted by Dellbertt on February 27, 2010 at 09:55:22:
Those are the rear gangs. They mount on the back of the tractor using the same studs as the drawbar. It looks like there is some sort of potato plow or row making shoe on the cultivator standard. There should be two gang assemblies to mount onto the rear of the tractor. The one pictured goes on the right rear so the bar curls around the tire and there should be one for the left rear that is the opposite shape. The bracket 3/4 of the way down the bar is where the rear lift rod attaches to with a hook. It then goes to the rear rockshaft behind the seat. There are two ways it can connect. Some have a bar going across the rear rockshaft and the lift rod has a part with a roughly 1" hole to slide on to the bar. A cotter pin is then put on each side of the lift rod to hold it in place. The other setup uses a piece on the lift rod that has a stud which goes through one of the holes of the rockshaft and a cotter pit is put through the stud so it doesn't slide back out. I hope I haven't confused you. If you go back to the CaseIH website, the first way of attaching the rear lift rods is listed under L-14 and the second way is shown under L-20(A). If you have any more questions, let me know.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
