Re: Crank Starting
Posted by Stephen McCoy on February 27, 2010 at 10:35:53 from (173.27.210.76):
In Reply to: Crank Starting posted by Bud W on February 27, 2010 at 10:24:45:
Yes and No.
I have an H and a B, both of which have distributor ignition AND have been converted to 12 volt with alternator.
I can crank start both of them BUT I must have a battery connected in order for it to work.
An alternator needs a current to energize the coils initially, after which it becomes self energizing (if you have it hooked up correctly).
If I remember correctly a generator has permanent magnets and therefor needs no outside current to begin generating electricity.
I think if you had a working generator it would start without a battery by hand cranking, but I'm not sure if that's right or not.
This post was edited by Stephen McCoy at 10:42:34 02/27/10 2 times.
