Re: Crank Starting
Posted by Janicholson on February 27, 2010 at 10:41:27 from (64.61.211.219):
In Reply to: Crank Starting posted by Bud W on February 27, 2010 at 10:24:45:
The battery needs to have enough juice to fire the plugs. (even 10 volts will probably do) The process is the same either way. (unless the tractor is very old and has a spark control lever, which must be in the retard position for starting).
Correct timing is TDC for both. Jim
