Re: Crank Starting
Posted by old on February 27, 2010 at 11:22:03 from (4.245.7.96):
In Reply to: Crank Starting posted by Bud W on February 27, 2010 at 10:24:45:
Well yes and no. Yes if the battery is good you can but if that is the case why. No if the battery is dead you can crank it till your blue in the face and the cows come home and it will not start. Also distributor type ignition do like to kick back and then in turn can/will cause you to get hurt if you do not hold the hand crank the correct way and even then it can still get you I know I spent time in the ER because of one
