Re: 400 rear swap with SM?
Posted by mkirsch on February 27, 2010 at 16:14:24 from (67.240.251.254):
In Reply to: 400 rear swap with SM? posted by pete_5959 on February 27, 2010 at 14:45:30:
The SM engine will bolt up to the 400 at the bell (clutch) housing.
That would give you a "poor man's" SMTA.
If you split it any further back than the bell housing, nothing will bolt together AFAIK.
The 400 rear end will make the tractor a few inches longer so you may need to modify a few things on the steering column.
