Re: Gaskets-Leaking
Posted by David G on February 27, 2010 at 18:34:22 from (66.211.0.69):
In Reply to: Re: Gaskets-Leaking posted by Andrew Z on February 27, 2010 at 17:56:15:
Mine was leaking on both ends, had to replace rear main seal and both transmission seals.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
