Re: Super H backfiring
Posted by Dellbertt on February 28, 2010 at 04:39:03 from (209.172.21.29):
In Reply to: Super H backfiring posted by nk7 on February 27, 2010 at 15:44:51:
Like Andrew and others have said it is more than likely just a slight timing adjustment.
It could also be the carb is set too lean for full throttle operation.
When the tractor starts to backfire pull the choke out slowly and see if things improve. If it does you need to set the carb richer.
Dell
