Re: Gaskets-Leaking
Posted by Andrew Z on February 28, 2010 at 08:08:53 from (64.252.41.103):
In Reply to: Re: Gaskets-Leaking posted by Farmall-H on February 28, 2010 at 08:03:33:
That wont work, you want that oil to either drain or stay in the engine. IF you put RTV on the outside it will keep the oil in the flywheel/bell housing. When running it will sling oil all over the clutch, flywheel and pressure plate, this obviously is bad. IF you let it drip out at least it wont build up there and get over everything. How much is it really dripping ? a cap full, a cup, or a quart?
Andrew
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
