Farmall Tractors Discussion Board
Re: H Electical
Posted by K-Mo on December 31, 1998 at 07:48:49:
In Reply to: H Electical posted by Dane on December 30, 1998 at 12:48:44:
Have you tried CASEIH?
My Farmall A parts book shows the following part numbers:
Dimmer-- 814545
Field-- 1878070 (Delco-Remy)
If your tractor has a Voltage Regulator installed instead of a Cutout Relay, you will not need the Field Resistor.
Post a Followup
: Re: Re: H Electical
