Re: Farmall A engine problems
Posted by El Toro on February 28, 2010 at 15:01:22 from (74.103.74.58):
In Reply to: Farmall A engine problems posted by Doug Stockman on February 28, 2010 at 13:21:17:
You need to see what your fire looks like at your plugs. Pull off one of the plug wires and hold it about 1/4" away from the plug while someone makes an attempt to start the engine. Don't forget to turn the ignition switch to the on position, if it has a mag the grounding switch needs to be in the run position. If you don't have a hot blue fire from the plug wire your coil is probably weak if you have a distributor. If its a mag it could the coil or the magnets if they're weak on magnetism. Hal
