Posted by Andrew Z on February 28, 2010 at 16:01:02 from (64.252.41.103):
In Reply to: h idle problems posted by jim from az on February 28, 2010 at 14:16:26:
does it stall when you idle it or just cant get it to go low enough? There is a screw on the carb right where the throttle shaft goes into the carb turn that screw out a turn that may solve it. If not youll have to remove the governor side cover and adjust the low idle in there. Check the external setting on the carb first though.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
