Re: AV gas, can you use it in older tractors
Posted by Hand Clucth on February 28, 2010 at 16:34:11 from (98.224.115.127):
In Reply to: AV gas, can you use it in older tractors posted by steve706 on February 28, 2010 at 06:52:24:
It works very well. It is a little on the dry side. I would recomend mixing a quart of diesel with 5 gallons of av gas when the tractor is stored for the winter. Staight av gas will stick the valves over winter!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
