If you are using a tag-a-long (bumper hitch) trailer and it is not over the wheels deck, the M will not fit between the fenders of the trailer unless the M wheels are turned in which is not likely. You will need for the wheels to fit, as to balance the load, the tractor will need to be forward so some weight is on the tongue of the trailer. If the M has loaded tires, it is going to be too heavy for your rig. It is essential for you to have trailer brakes as well when hauling this much weight. Anything over 2000 lbs is required by DOT to have trailer brakes. You don't say what kind of vehicle you are pulling with, or how far you have to go. If a short distance, you can probably push things a little but if you are going far, you best make sure you are with up on everything. For hauling an M, you really need at least a 3/4 ton truck as the towing vehicle.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
