Re: What hitch ball to trailer a Farmall M?
Posted by GordoSD on March 01, 2010 at 05:37:53 from (216.106.251.21):
In Reply to: What hitch ball to trailer a Farmall M? posted by 3500sport on February 28, 2010 at 17:27:26:
Get a 2 5/16 ball. It should be marked 10,000 pounds on it. Then get the proper slide in coupler. That shoulsalso be marked 10,000 pounds. TSC has them.
Then get your brake controller installed in your cab.
Drive the whole affair to the rental place and have them wire up your lights and brake controller and check everything working
Have a merry trip.
DON'T use a 2 inch ball, and DON'T go down the road with a plain old hitch that you don't know the rating on.
