Re: Thinking About Buying a H
Posted by sflem849 on March 01, 2010 at 06:52:11 from (69.197.84.192):
In Reply to: Thinking About Buying a H posted by sflem849 on February 28, 2010 at 16:32:56:
GordoSD said: (quoted from post at 06:47:25 03/01/10) If it won't start and run well, about $400.
If it does start about $700. Point out to her the bad rims and tires, and that cobbled up seat.
If you get it home, expect those tires to be loaded. They ahve a lot of tread on them and I wouldn't worry about the weather checking. I think they will last you a good ten years or more.
Gordo
That is what I thought about the tires as well. (And the price for that matter) If they hold air and don't have cracks that go to the casing they will last for a LONG time on most tractors. They would last 10 years for Gordo and he actually farms with his! I might even use them for tractor pulling. They would be perfect tires for that since they are so old and have the right amount of tread. They look like 45* bars though...
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
