If the loader cylinders extend all the way out you most likely have enough oil in the system. Check the oil level with the loader cylinders retracted and the hitch down. The reservoir should be filled to the bottom of the plug hole.
Most likely your problem is a dirty filter/screen. It is located in the hydraulic reservoir on the suction tube. To service it you need to drain the oil. Remove the hose coupling on the suction tube by sliding it forward enough to clear the end coming out of the reservoir. Pull the tube from the reservoir with a twisting motion.
If you should have a front crankshaft mounted pump,an option on the 2444, then the hydraulic reservoir is combined with the transmission housing.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
