Re: 450 transmission pinion locked up?
Posted by The tractor vet on March 01, 2010 at 10:14:38 from (75.19.124.251):
In Reply to: Re: 450 transmission pinion locked up? posted by Wardner on March 01, 2010 at 09:55:51:
Now i have seen it where you can remove ALL the brake housing bolts and the brake housing is plum STUCK and repeated wacks from a 4 # hammer had a problem getting them to break loose . Never force anything --------GET A BIGGER HAMMER !!!!!!!
