You would need to make up brackets to mount flat top fenders solidly to a 450 axle housing. There are no such brackets pre-made.
Frankly, flat-top fenders look DUMB on a 450, but if it floats your boat, have at it. You sit way too far back on a 450, almost behind where the fenders cover. Newer tractors with the flat-tops have the seat moved quite a bit forward so the fenders actually protect you.
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor.
... [Read Article]
Latest Ad:
[More Ads]
