Posted by El Toro on March 01, 2010 at 16:35:54 from (74.103.74.58):
In Reply to: H mag moisture problem posted by Zachary Hoyt on March 01, 2010 at 16:18:26:
When it quits running pull off one of the plug wires and hold it about 1/4" away from the plug while someone else makes an attempt to start the engine. You need to do this asap before the coil cools. You should have a hot blue fire from that plug wire. If you don't it could be the coil or weak magnets without much magetism. The magnets help create that hot spark when they pass by the coil. If there's fire to the plug looks ok you may have a fuel issue where something may be blocking the fuel flow between the tank and carburetor. Hal PS: You may want to use a pair of insulated pliers so you don't get bitten.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
