Posted by Dave Allgire on March 01, 2010 at 17:20:52 from (24.217.36.77):
In Reply to: F-12 hyd lift? posted by GNP Fatboy on March 01, 2010 at 15:36:09:
Yep, that is a hydraulic lift. It was used with several implements that were designed to work with it. It should have a manifold assembly that goes from the lift to a pump on the left side of the shaft that drives the belt pulley (viewed from the drivers seat). As to value, maybe $150? The tractor seat is mounted on a piece of spring steel that curves around the lift. When the tractor has this pump mounted on it, you cannot use the post type seat.
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
