Farmall Tractors Discussion Board
Mounting H Radiator
Posted by Jim T on December 31, 1998 at 08:20:18:
Does an H radiator rest on springs on top of the upper bolster or does the radiator set directly on the bolster with the springs placed on the studs from the underside of the bolster? Also, are the studs brazed or welded to the radiator or are they removal? Thanks for the help.
Post a Followup
: Re: Mounting H Radiator
