Posted by pete 23 on March 01, 2010 at 17:43:45 from (173.87.0.197):
In Reply to: 300U Hydraulic pump posted by Rick Bachman on March 01, 2010 at 16:18:05:
You need to determine if your system is staying on high pressure or not. If it is it will heat excessively and cause poor pump performance. This could very well be caused by plugged orfice in regulator valve assembly or settings on aux valves single to double action having been turned too far due to broken or bent roll pin. Hydraulic pumps for these tractors are extremely expensive so you surely should have it flow rated before you even think of buying a new pump.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
