Posted by Justintime on March 01, 2010 at 17:49:08 from (69.66.66.177):
In Reply to: 49 M valves posted by Justintime on March 01, 2010 at 09:54:42:
THANK YOU FOR THAT MUCH. I SHOULD HAVE MENTIONED I HAVE ALREADY CONVERTED TO ELECTRONIC IGNITION AND THAT HAS HELPED. AS FOR RUNNING OUT OF POWER OR TRACTION FIRST, I HAVE HAD BOTH HAPPEN. I USUALLY LOOSE TRACTION FIRST AT 5500# BUT IT CAN GO EITHER WAY ON HEAVIER WEIGHTS DEPENDING ON THE TRACK. CARB WORK IS COMING UP ALSO THIS WINTER. HOW MUCH CAN I DO WITH THE CARB AND STILL KEEP THIS TRACTOR AS A USER.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
