350U Governor
Posted by Formerly PaMike on March 01, 2010 at 17:58:24 from (24.152.202.123):
I had an intake manifold leak on my gas 350U. I pulled the manifold and carb tonight to replace the gasket. When putting it back together I was trying to get the governer linkage back into the carb and get the manifold back on the studs. I got everything back together with out forcing anything, but I am concerned that I got the govenor shaft back on the carb correctly. Is there any way to tell? It looks like the shaft had a pin on it that fit in a slot in the carb linkage, but it looked like you could also put it together with the pin not in the slot. Any way to tell for sure that it is right before I button everything back up?
Thanks
