Re: F 14 Farmall
Posted by James Williams on March 02, 2010 at 06:21:41 from (170.215.170.103):
In Reply to: F 14 Farmall posted by IHC53 on March 02, 2010 at 05:25:31:
A F 14 carb is more critical than you think.Sounds like the float is sticking or the needle valve.If the float is not set properly it will be hard to start.Timing is very important,With out using a static timing light trial and era has been the best bet.Only make one adjustment at a time
jimmy
