Re: F 14 Farmall
Posted by charlie M on March 02, 2010 at 13:48:29 from (70.101.104.228):
In Reply to: F 14 Farmall posted by IHC53 on March 02, 2010 at 05:25:31:
I had similar problems with my F14. Found a lot of corrosion in the fuel line and wasn't getting enough fuel. I put on a new fuel line and problem went away. Concerning the hard starting I've found mine starts better with hotter plugs. I use D21 in mine. Mine starts well if run every couple of weeks but longer than that it is real hard to start without a lot of cranking.
