Re: oil out of the exhaust
Posted by Andrew Z on March 02, 2010 at 18:34:09 from (64.252.41.103):
In Reply to: oil out of the exhaust posted by jbrahm83 on March 02, 2010 at 18:26:29:
your not getting it up to running temp, what it is doing is called 'wet stacking' or 'slobbering' by some. I would try and get that engine up to a good hot work out and see if that helps. IF you dont see the the temp gauge move either you have a bad gauge or a bad thermostat. If the thermostat is stuck open its pretty hard to get them up to temp with out it.
Andrew
