Re: Converting Farmall M from propane to gasoline...
Posted by NDS on March 03, 2010 at 06:16:42 from (64.12.116.73):
In Reply to: Converting Farmall M from propane to gasoline... posted by 3500sport on March 02, 2010 at 19:19:19:
I have converted M back to gasoline and it is not a big deal. You will need tank, sediment bowl, gasoline line, carb. and probaly different hood. LP manifold will work with gasoline but I prefer gasoline manifold. I have burned MANY thousand gallons of LP in tractors, cotton pickers. trucks and forklifts and the only advantages I saw were longer engine life and lower fuel cost but now the cost advantage is not there engine will burn about 20% more LP than gasoline. If compression has been raised you might need to burn high octane gasoline but I have never needed to.
