Re: Voltage Regulators
Posted by Bob on March 03, 2010 at 08:28:25 from (69.178.228.68):
In Reply to: Re: Voltage Regulators posted by Bob M on March 03, 2010 at 08:21:09:
BobM,
It would be pretty tough to come up with a SIMPLE design that would keep the "L" terminal "hot" at all times AND bypass the lighting current around the current sensing coil.
Also, since the current limiting function of the regulator is typically set to what the generator can safely handle BYPASSING the lighting current around the current regulator could cause the generator to overheat and burn up if there was a large non-lighting load AND a large lighting load.
Therefore, I don't think they are set up so the lighting load bypasses the current relay coil.
HOWEVER, I will defer to what you discover upon your regulator inspection!
Today's Featured Article - Tractor Profile: Earthmaster - by Staff. This tractor, manufactured by the Earthmaster Farm Equipment company in Burbank, California was made for only two years. The Model C came out in 1948 and was followed by the "CN" (narrow-width model), "CNH (narrow-width high-crop model), "CH" (high-crop), "D" and the "DH" (high-crop) in 1949. The main difference between the models was tire size, tractor width and cultivating height. The "D" series were about 20 inches wider overall than the ... [Read Article]
