Re: H Manifold Gasket
Posted by MisterT on March 03, 2010 at 08:38:06 from (209.152.78.140):
In Reply to: H Manifold Gasket posted by The tractor vet on March 02, 2010 at 17:59:25:
sflem849 said: (quoted from post at 17:23:12 03/03/10)
GordoSD said: (quoted from post at 09:18:28 03/03/10) You should have the thick manifold washers on the four studs where the manifold is split. WHile you have it iff, take it to a shop and have it planed just enough to be perfecr flat. Then sandblast, paint your choice of color with hi temp manifold paint and install.
Gordo
I was going to say leave the carb and gov hooked up if you can and try and sneak the gasket in.
I hate getting that tang lined up with the gov tube. It is also a PITA to get the nut on the backside of the carb.
I understand where you're coming from, but you'll never get the mating surfaces cleaned up good enough without total disassembly.
