Re: cub sickle bar
Posted by mkirsch on March 03, 2010 at 09:41:10 from (64.80.108.55):
In Reply to: cub sickle bar posted by washingtonMark on March 03, 2010 at 06:00:25:
The cutterhead assembly is IDENTICAL between the Cub and Super A versions.
However, the mule drive is completely different. The Cub's is too short and has the wrong pulley ratio for an A. The cutterhead will hit the rear tire, and the bar will not move fast enough if you use a Cub drive on a Super A.
You need a Super A mounting frame and drive pulley to make it work. If you're anywhere near Rochester NY I know where you can get one.
PTO direction is irrelevant. It doesn't matter if the sickle bar goes left-right-left-right, or right-left-right-left.
