Posted by jim from az on March 03, 2010 at 10:31:37 from (67.40.93.102):
In Reply to: Re: farmall h governor posted by jim from az on March 02, 2010 at 17:00:57:
i took the cover off and everything looks good oil on it, weights are good, bearing moves,doesn't seem to be worn anyhere. there is play in the bottom spring that must be because of the play in vertical shaft.. should i remove the pins in the vertical shaft at top and tighten it i'm sure i have the tang in the carb right as i can control the speed of the engine by pushing and pulling the vertical rod right??? should i tighten the vertical rod ??thanks for your help
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
