Re: IH 384 HYD System
Posted by jimb2 on March 03, 2010 at 13:45:38 from (99.240.236.11):
In Reply to: IH 384 HYD System posted by Billy Shafer on March 03, 2010 at 08:19:25:
Hi the 384 Diesel that we had with Power Steering had 2 hydraulic pumps stacked one behind the other. One pump fed PS, the other 3pt hitch. There is a filter in the suction line at front of the hydraulic reservoir under the seat. There is also a couple valves on front of reservoir, one controls hydraulic flow rate to 3pt the other controls hydraulic flow to 3pt OR flow to remote hydraulic outlet. This valve must be in proper position for 3pt to work. I have seen another design where there is only 1 hydraulic pump and a splitter valve that splits flow between PS and 3pt. Also make certain draft control level (lever closest to fender) is fully forward.
Good Luck
Jim
