Posted by MisterT on March 03, 2010 at 13:53:28 from (209.152.78.140):
In Reply to: H Manifold Gasket posted by patrick in illinois on March 02, 2010 at 17:59:25:
sflem849 said: (quoted from post at 20:59:32 03/03/10)
MisterT said: (quoted from post at 09:38:06 03/03/10)
sflem849 said: (quoted from post at 17:23:12 03/03/10)
GordoSD said: (quoted from post at 09:18:28 03/03/10) You should have the thick manifold washers on the four studs where the manifold is split. WHile you have it iff, take it to a shop and have it planed just enough to be perfecr flat. Then sandblast, paint your choice of color with hi temp manifold paint and install.
Gordo
I was going to say leave the carb and gov hooked up if you can and try and sneak the gasket in.
I hate getting that tang lined up with the gov tube. It is also a PITA to get the nut on the backside of the carb.
I understand where you're coming from, but you'll never get the mating surfaces cleaned up good enough without total disassembly.
I hear you, but I would sure give it a try!
You will only meet with failure and you will be buying another manifold gasket. Do it right the first time and it will be done for a good, long time.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
