ignition problems
Posted by Al Olson on March 03, 2010 at 14:57:45 from (74.211.20.112):
I have a 1946 H that has the small, 5 inch by 2 inch coil. It will not start or run with the coil wire attached to the distributor, if I remove it from the distributor and leave it about 1to 2 inches free it will start and run. Am I correct in assuming that the coil is bad?
