Re: M W Hand clutch
Posted by dougct on March 03, 2010 at 15:17:43 from (71.234.250.61):
In Reply to: M W Hand clutch posted by Dale Hollen on March 03, 2010 at 14:45:50:
I have one on my M and it works great.It was slipping so my manual said to take of the small center plate and you"ll see a large nut with a lock washer with bent tab"s,bend back the tabs and give the nut a small turn it doesn"t take much.Bend back the tabs and put the plate back on,if that doesn"t work your disks could be too worn.Just remember your power goes through that clutch first,so no matter how good your M clutch is its only as good as the M&W.Hope that helped a little.
