Re: Super M hydraulic fluid
Posted by DeltaRed on March 03, 2010 at 20:52:55 from (97.122.253.147):
In Reply to: Super M hydraulic fluid posted by MNC on March 03, 2010 at 19:40:10:
Here did you add this oil?rear/trans and hydraulics are totaly separate.Do you have a 'magpump' or 'bellypump?read your book again!
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
