Re: Super M hydraulic fluid
Posted by rustred on March 03, 2010 at 23:46:47 from (74.198.148.45):
In Reply to: Super M hydraulic fluid posted by MNC on March 03, 2010 at 19:40:10:
your ok,you dont need to waste your oil. the hyds. are a separate unit on those tractors.book has to be referring to a unit like 560 with pump in trans.housing.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
