Re: Need Good/Bad info about IH 250 Ind. tractor....
Posted by gurneejoe on March 04, 2010 at 05:13:02 from (205.188.116.73):
In Reply to: Need Good/Bad info about IH 250 Ind. tractor.... posted by Dan Swanson on March 03, 2010 at 20:10:52:
The 240/250/260 series was the last version of industrial loader/backhoe tractors produced before International sold out to Case and Dresser. They had Deutz engines from Germany and were assembled in the south somewhere like Georgia or Alabama. Front axles were very heavy duty with cast I-beam crossmembers and wide front tires. If I remember correctly they had a hydraulic forward and reverse lever on the dash for easy loader work.They used ether injection for cold starting. I can't think of any negatives.
