Cut-out systems didn't have a full voltage regulator, just a cut-out unit mounted on top of the generator. The cut-out disconnected the generator from the battery when the generator wasn't charging to keep the battery from discharging through the generator. Later tractors had a voltage regulator mounted below the generator that controlled generator voltage and included the cut-out.
Prior to including ground wires in the harness, the electrical ground connections were provided through the tractor chassis and sheet metal. All electrical components have to be mounted with a good ground connection.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
