Iowaboy said: (quoted from post at 15:47:22 03/04/10) I could sure use some help. I have light rust in the gas tank of my H. The rust is mostly on the roof of the tank, and rust keeps dropping down into the gas. It isn't heavy rust -- just enough to cause problems once in a while. I'm going to take the tank off to clean it, but what should I pour into the tank to help get rid of that light rust? I've been told to put washers and bolts in the tank and roll them around with kerosene. Does anyone know anything that will work better to loosen the rust? Thanks for your help.
Those washers and bolts will get lodged behind and under the baffle, and you will never get them out. If the rust is only light, just start using the tractor and clean the sediment bowl on a regular basis. Eventually you will have no more trouble.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
