Re: MW Hand Clutch
Posted by D Slater on March 04, 2010 at 13:03:01 from (71.164.36.19):
In Reply to: MW Hand Clutch posted by Andrew Z on March 04, 2010 at 09:41:07:
Well if you already have the clutch set up it would just cost some time to give it a try and remove it if things didn't work out. Not that big a deal on a SM. No deck lid, or pto, bull gear or axles need moved or removed on a SM to install or remove one.
Sometimes you can help the clutches hold if worn enough or fiber plates are made a little thiner, by adding another fiber and steel plate to the pack. You do know you end up with a band brake on the clutch side and a disk brake on the other side?
Today's Featured Article - Ford Super Dexta - by Anthony West. The rusty blue tractor caught my eye as my truck zipped by the farm implement business. It looked so fornlorn amongst the lineup of newer equipment. But it was just the right size for my small farm. I stopped in and asked the proprietor for further information. "It's a 64 Ford Super Dexta", he said. "It's a tough little tractor, although it's a hard starter being a diesel and all." He did manage to get it running, compliments of a can of ether. Once started it putted along pretty good. It ... [Read Article]
