Re: MW Hand Clutch
Posted by Andrew Z on March 04, 2010 at 13:37:41 from (64.252.41.103):
In Reply to: MW Hand Clutch posted by Andrew Z on March 04, 2010 at 09:41:07:
It wasnt really to hard to get the hp up alittle, the biggest problem was setting the timing, cover off, cover on, cover off, cover on, repeat 10 times.... The pump and injectors were rebuilt and im looking at swapping pump guts around to get me another 10 or so. I was just thinking about a hand clutch because im going to be doing some hay this summer and was thinking that the SMD would be a nice baling tractor. If i had some form of 'live' pto.
thanks guys as always
Andrew
Today's Featured Article - Storing Your Tractor - by Staff. If your tractor is going to be stored for any length of time, a few precautionary measures are helpful in preserving various parts, also in avoiding future difficulty. Store tractor under cover. If impossible to place tractor under cover, be sure to cover air stack and exhaust pipe. Drain radiator and engine block. To avoid gum content collections, drain both fuel tanks and carburetor. Leave radiator and fuel caps slightly loose to protect gaskets. Block tractor up to remove weight from tires and to keep tires from contact with moist floor. ... [Read Article]
