Re: CUB WILL NOT START
Posted by Ray in CT on March 04, 2010 at 14:28:38 from (24.2.243.85):
In Reply to: CUB WILL NOT START posted by CODY H on March 03, 2010 at 19:13:19:
I had this very similar problem with my M recently. It was 180 degrees out of time, And I also had a stuck valve. Just triple check your timing. and worse case pull the valve cover off and have someone turn the motor over and make sure all the valve are moving properly.
