Posted by Harold H on March 04, 2010 at 15:47:01 from (98.18.169.62):
In Reply to: Factory Fenders On H? posted by genos on February 28, 2010 at 18:38:06:
Leo,
I agree with you that fenders look out of place on an older Farmall. I also believe that older Farmalls look much better with a tricycle front end rather than a wide front end. Wide front ends did not become real common untill the 60's in the Delta.
Today's Featured Article - Timing Your Magneto Ignition Tractor - by Chris Pratt. If you have done major engine work or restored your tractor, chances are you removed the magneto and spark plug wires and eventually reached the point where you had to put it all back together and make it run. On our first cosmetic restoration, not having a manual, we carefully marked the wires, taped the magneto in the position it came off, and were careful not to turn the engine over while we had these components off. We thought we could get by with this since the engine ran perfectly and would not need any internal work. After the cleanup and painting was done, we began reassembly and finally came to t
... [Read Article]
Latest Ad:
[More Ads]
