Re: farmall super c and c radiators
Posted by ScottyHOMEy on March 04, 2010 at 18:29:55 from (70.105.254.59):
In Reply to: farmall super c and c radiators posted by jim A. on March 04, 2010 at 17:43:37:
Sorry, but no. The Super C radiator (and, therefore, the grille) are taller. All of which leads to there being a different coolant outlet neck from the head to the radiator to bridge the extra height, and for the fuel tank being raised higher over the Touch Control block on the Super C (one of the identifying charactersitics that distinguishes it from the C) to mate up with the added height up front.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
