old pto hyd unit
Posted by Dave54 on March 04, 2010 at 19:05:18 from (75.17.218.71):
I came across this unit that was on a M and am trying to get it to work. Don't know anything about it and cannot find any information on it either. It is self contained in this canister with the pump screen and valve inside. Would like to know oil they used and also pressure and volume specs. If anybody has that info it would be greatly appreciated. Thank you
Today's Featured Article - Talk of the Town: How to Remove a Broken Bolt - by Staff. Another neat discussion from the Tractor Talk Discussion Forum. The discussion started out with the following post: "I have an aluminum steering gear housing with a bolt broken off in it. The bolt is about a 3/8" x 1 1/2" bolt. I've already drilled the center of the bolt out with about 7/64" drill bit the entire length of the bolt. Only one end of the bolt is visible. I tried to use an easy out but it wasn't budging and I didn't want t ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
