Forget anything loose in there. You get it behind the baffle and you are in trouble. You don't get it behind the baffle and you won't get that part clean.
Go buy a gallon of muriatic acid. Plug off the drain hole and put some duct tape over the vent hole in the cap. Roll the tank all around to coat all the surfaces. Let it soak for several hours upside down. Flush with plenty water and some gas to get the water out. Finished. If you want to make the acid go farther, you can cut it with water 50/50.
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
