Fuel problem IH-424
Posted by Heyseed on March 05, 2010 at 10:24:45 from (68.57.135.218):
I have a 1967 IH-424 gas. Seems to be starving for fuel, can"t keep her running unless I use a lot of choke. Had some nasty stuff in the glass bowl. I cleaned that and it helped but it acted like the float was stuck. I drained the bowl (pulled the screw plug) on the carb and shot some gum cutter up inside. It helped but still is not right. I want to rebuild the carb, but am not sure how to identify the carb make and model. I want to make sure I order the right kit.
thanks for any help.
